Recently replaced thermostat, hoses, impeller, manifold to riser gaskets, cleaned the water jackets in the risers and remove alot of debris.
Now here is what happens and what happened.
1.) When cruising for several minutes, I get the loud "BEEEEP" telling me something is wrong. So I come off plane and check my gauges, everything looks fine.
Temp guage says its fine, oil pressure says its fine. No warning lights.
I turn off the engine and immediately fire it back up and no warning beep. So I go back to cruising, a few minutes later, same thing. Repeat process, come off plane, turn off engine, turn on engine everything runs fine.
I wonder if I might be getting air into my water system similar to the thread on overheating? Thoughts on this?
2.) If I wanted to, could I run the engine without the thermostat just to rule out the possibility that it is somehow incorrectly installed? Or is that a bad idea?
3.) The second time the buzzer went off, I turned the engine off and didn't have it OUT of gear. There was a "POP".
I shifted it the rest of the way into neutral (with the engine off) and started it back up. No problem there.
However, when I put it into drive, there is a delay in the drive engaging now. The RPMS increase, and there is a lurch when the drive engages.
Now I have to shift forward quickly (without accelerating) and wait a split second for the drive to engage and then throttle up.
This has me greatly concerned. Could the alignment between the shift cables and the transmission be out of wack? Or is it something else?
I have both the service manual and the drive manual but I would like to ideas where to begin. If it is adjusting the shift cables, I have that special tool required to align the shift cables (assuming I can find it).
Thanks!
Chris
P.S. Thanks Don et.al for the previous help regarding the overheating problem!!!
Thanks!
Chris
