  #1
Old July 2nd, 2008, 05:13 PM
scottrbishop scottrbishop is offline
Default 1978 Mercury 115 Throttle/Shift Linkage?
Hey everyone,
Finally got to take the restored Glastron out on the lake this weekend. She ran very well for a first trial run. Transom seemed very solid.
I think I must have the throttle and shift linkages incorrectly adjusted. When I push the control Box handle forward, the distributor doesn't start to move until I extend the arm pretty far forward, and of course, that's about where the motor starts to pick up some throttle.
The motor also starts in a few slow forward gear, Neutral and Reverse don't seem to be working at all right now.
Can somebody walk me through how to get these correctly set? Is it a trial an error thing or is there an easier way to get this set correctly? Should I take it to a mechanic?
Thanks,
Scott
  #2
Old July 2nd, 2008, 05:47 PM
Chris1956 Chris1956 is offline
Default Re: 1978 Mercury 115 Throttle/Shift Linkage?
Scott, There is no adjustment on the control box. All adjustments need to be done on the motor. Is it possible you have the shift and throttle cables switched. Remember the shift cable moves first, as you push the handle forward. The throttle cable then starts to move.
If the motor is adjusted properly you should put the control into neutral. Make sure the motor is in neutral. Now attach the shift cable to the 1/4" bolt on the shift arm. Adjust the barrel nut until it fits into the clamp.
Now attach the throttle cable to the 1/4 bolt on the throttle arm. Now adjust the barrell nut to fit into the clamp, but add a turn or two to preload the throttle. Make sure the throttle goes to WOT (motor not running), when the throttle handle is pushed ot the max.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'84 johnson 115 mid throttle and shift linkage jstme Johnson & Evinrude Outboards 4 June 11th, 2007 10:46 PM
Lubrication - throttle and shift linkage jal Johnson & Evinrude Outboards 5 December 3rd, 2006 02:08 PM
Throttle / Shift cable Linkage Problem WVU FAN Boat Topics and Questions (not engine topics) 2 October 26th, 2005 12:29 PM
OMC shift linkage/throttle agjustment.... Manipulator Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 April 22nd, 2005 01:23 PM
1978 Mercury 80 HP M800 ( throttle/shift cable removal? ) SampKamp Mercury & Mariner Outboards 2 December 22nd, 2004 06:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
