Hello, I bought a boat last year and I am not really sure what type of maintenance i should do with the engine. I know I would like to replace the lower unit gear lube but I am not sure what type of lube to use. I have an evinrude 175hp the boat is 1983 so I assume the engine is the same. What type of lube do I need? Can you recommend any other service I should do on it? Thanks.
