I have a question for you guys. I have a Fulton T2605 winch that came from factory I guess on my 2001 ex loader bunk trailer. Now the strap which is over 7 years old started coming apart and the winch itself wouldnt lock anymore. And started bending around the latch part. Not sure If its from age or just not being strong enough. I have a 21ft CC.
So I decided to upgrade the winch to a Fulton T3205 which doesnt come with strap or cable.
Now question I have is. On the box it says Cable only for this model due to the lager size drum. Can I use a HD strap instead? 2X25ft Or should I just stay with the cable. They recomend the 7/32 X 25ft. which has the capacity of 5600 lbs. and the strap has a cap. of 10000 lbs. I would rather go with the strap since I wouldnt have to worry about the rust or cable splintering from what I've read.
Thanks!
Thanks!
