  #1
Old July 2nd, 2008, 01:42 PM
davidf5252 davidf5252 is offline
Default 1988 Mariner 115 electrical issue?
First off i have a dual battery system on my boat. One cranking battery, lights, accessories, fish finder and the other one is only hooked to the trolling motor....
Well i started my boat up about 9pm to head back to the boat ramp and it cranked right up...Then i got to the ramp and put the boat up on the shore to go get the truck i let it idle while i was backing the trailer.
Ok, so i hop in the boat and drive it on the trailer and after it was on the trailer i was giving it gas to make sure it went all the way up and i noticed my lights get really bright when i hit the gas (this was not happening while driving it to the trailer)...kind of like they were hooked directly to the motor or something...bc that motor puts out 9amps to charge the battery while its running... the volt meter was also jumping form 10amps to 20+ when revving it up..
So i turned it off and tried to start it the battery was completely dead i mean completely...as in clicking when trying to start it (like a car with a dead battery) and the trim didnt work and lights were VERY faint...The volt meter on the boat read 0...
I went home and put the battery on charge and came out this morning to turn the motor over and it clicked again and the trim didnt work...The volt meter on the boat was showing 12+ volts
So i thought it was the battery and maybe it had a dead cell but i just took it to Autozone and the battery was 100% charged and in perfect working order...
ALSO...I replaced the regulator and stator within the last 2 months...
So I dont know what to do at this point.....
Thanks in advance for all the help!!
  #2
Old July 2nd, 2008, 02:55 PM
Default Re: 1988 Mariner 115 electrical issue?
any one?
  #3
Old July 2nd, 2008, 04:07 PM
j_martin j_martin is offline
Either the battery is completely shot, or one of the connections to it is bad.
The battery can be tested at NAPA, or Clown Auto, or even Wal-mart.
Yer charging system is good.
Note that your system does not have a voltage regulator. The voltage is limited by the battery. Routine battery maintenance will minimize the damage from overcharging, but the battery will use water, and if allowed to get too low on water it will self destruct. Don't even think about gel-cell or AGM batteries. Just put in a cheapo group 24 marine motor starting battery and plan on routine maintenance and replacement every 2 - 3 years.
hope it helps
John
  #4
Old July 2nd, 2008, 04:08 PM
Thanks John...i fixed the problem...
After testing the regulator and the stator and the battery it was nothing more than dirty terminals which should have been the first thing i checked DOH!!
all is well thanks for the help!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 115 Mariner Power Trim and Tilt issue Stripersonthebeach Mercury & Mariner Outboards 3 May 14th, 2008 04:12 PM
Electrical Issue? rndn Johnson & Evinrude Outboards 1 July 28th, 2007 09:58 AM
Electrical Issue 72INVADER90HP Johnson & Evinrude Outboards 7 September 25th, 2006 12:47 PM
92' 90hsp mariner electrical issue myket1 Mercury & Mariner Outboards 3 September 19th, 2004 03:10 PM
1988 Mariner 115 Temp Sending Unit lgreen8303 Mercury & Mariner Outboards 5 December 3rd, 2002 08:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
