ironhead333
- Jun 5, 2008
- 4
Motor ran fine last season. I broke my foot last fall and was unable to winterize. This season, it ran fine until the first slow wake zone, and then the no power symptom occurred.
I've cleaned and then rebuilt the carburator, replaced plugs but still no joy. Motor starts fine. Runs as it should +some out of gear. When gear is engaged WOT provides no more than idle speed.
Suspect fuel pump, or float. Can't find float part number. NAPA couldn't either.
Bought a "parts motor" from craigslist. The fuel pumps are different because neither originally had a fuel pump, but had a pressurized fuel tank.
One is mounted external to the cover and runs a line to get vacuum. The other mounts directly to the a port on the side of the engine. I'm not sure which one is correct, and don't know the part number for either.
I've purchased a .pdf manual for the engine, and many more, however, part numbers aren't included. Explosions are.
I'd like to determine, which, if either of the fuel pumps is usable as is, or get part numbers for a fuel pump for the boat motor in the title of this post.
Thank you for you time. I've tried to be brief. I'll answer any further questions that might help resolve my issue.
