Re: XP150 will not shut off
The engine shuts off when the power packs are shorted to ground. The key switch grounds the power pack yellow wire with black tracer. You should check the key switch first. If not, check the continuity of that wire. I have seen one pack not shut off, and the engine continue to run, despite the other pack grounded. Remote chance it is a bad pack.
