  #1
Old July 1st, 2008, 09:12 AM
GRDANAPAUL GRDANAPAUL is offline
Cool 89 100 Mariner Plug Fouling
New to forum looking for help on a 89 100 hp Mariner, variable rate oil injected. Intermittently 1 or more plugs will foul. After removing plugs and wiping off and cranking engine motor will work perfectly.Typically once motor gets "cleaned out" the motor will be fine all day. Occasionally if you have motor off for a couple of hours, say you are fishing, and start up it might fail. Motor always starts. I drained the fuel tank this spring, and filled with fresh fuel. I have rebuilt the fuel pump, tried new spark plugs. I use quicksilver oil. I have been through the carbs. It seems like excess injection oil is getting into the cylinders. Any ideas would be appreciated.
Dana
  #2
Old July 1st, 2008, 09:58 AM
Chris1956 Chris1956 is offline
Default Re: 89 100 Mariner Plug Fouling
OK - First of all, when you stop for a while the gasoline will evaporate leaving a rich oil mixture.
Have you checked the linkage to the oil pump for proper operation? Also check your fuel line for air leaks. If there is an air leak in the gasoline supply, the oil pump will overpump oil.
  #3
Old July 1st, 2008, 03:02 PM
Wink Re: 89 100 Mariner Plug Fouling
I have checked and re-checked the linkage and alignment of oil pump linkage per service manual. You might be on to something w/ regard to air leak. The fuel line s on carbs have all been replaced and clamped/ tie wrapped . the fuel line and primer bulb to tank has been replaced also. I did run it last fall on a separate fuel tank and the problem seemed to go away, but it is an intermittent problem, that is what caused me to drain the on-board tank and fill with fresh fuel. The fuel does seem to drain out of carbs quickly. It seems if I pump the primer bulb prior to any start I can usually avoid the problem. Should there be a check valve in the tank that may be failing? Can I install a check valve in the line? Maybe o-rings on fuel fitting on engine connector? I will triple check those items.
I really appreciate this help.
Dana
  #4
Old July 1st, 2008, 03:52 PM
j_martin j_martin is offline
I'd bet on the check valve in the primer bulb being bad. Throw out that aftermarket chit and put on a mercury/quicksilver line.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
89 Mariner 100 Misfire GRDANAPAUL Mercury & Mariner Outboards 0 June 29th, 2008 11:12 PM
98-99 mariner 60 bigfoot plug fouling manxman306 Mercury & Mariner Outboards 1 July 3rd, 2005 11:47 AM
Lower plug fouling & water on spark plug issues solved!!! ntoracn@yahoo.com Johnson & Evinrude Outboards 1 July 25th, 2004 09:24 PM
'89 75hp Mariner. Spark Plug Help. Johnny O' Mercury & Mariner Outboards 4 July 12th, 2003 04:13 PM
89 mariner 40 water comming out arround top spark plug duanes72 Mercury & Mariner Outboards 1 May 6th, 2002 12:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
