Ficht 200hp ECU overheating problem
rusler
The problem is that the output side of the ECU cool circuit gets plugged up causing a code 25 and the engine idles only.
The other day while clearing it I found some gritty stuff that almost would pass for sand but it shouldn?t be as I have never run aground or go in low water.
Any ideas?
Did the factory put out any modifications to this cooling circuit?
Anyone come up with a fix?
I was thinking of doing some hose modification.
Any suggestions would be appreciated.
