I have a 1983 75 horse mounted on a 17ft 1971 Glastron Crestflite. When the throttle at the drivers seat is at full throttle I have looked at the throttle on the engine. I have maybe a half to one inch left where I can manually push it down and get more speed. Right now the engine usually runs at about 4100 to 4200 rpm at full throttle. Would it be safe for the engine if I adjusted the throttle cable to where I gould get that last bit of throttle for more speed or should it be left alone ?
Is 4200 about right at full throttle ? Im getting about 28 mph according to the gps. The other question is Im wondering what brand name of repair manual is preferred as I have seen a couple different aftermarket brands. And last of all would a prop change get more speed ? Im pretty sure the one on it is the factory prop.
Regards........... Jim up near Flathead Lake Montana
