'68 55 hp Evinrude - cooling question
I am just beginning to check out a 1968 55 hp Evinrude Triumph with hydro-electric shift outboard.
I put the muffs on it, and after a bit of guessing/poking/prodding, got the thing started and running. I noticed there was no water coming out of the two "water discharge and exhause relief" jut under the exhaust covers. Should there be? I shut the engine off pretty quick so I hope there was no damage.
Also, I was not able to get the motor to shift into neutral or reverse. I will follow the advice in past posts on diagnosing this problem. My question, however, is: if I drain and install new lower unit (type C) lube to test that part of the shifting problem, will it have to be drained (and wasted) before I change the impeller for the water pump?
I have a (Factory) service manual that is rather confusing, since it assumes the mechanic wants to disassemble the entire motor, and only describes changing the impeller as part of a complete overhaul. I have a Clymer manual on the way in the hope it will give me instructions on how to go about changing the impeller without disassembling the entire motor. My hope is that I can simply drop the lower unit, change the impeller, and put the whole thing back together again.
Help???
