  #1
Old June 30th, 2008, 02:38 PM
BuoyChaser BuoyChaser is offline
Default Mercury 9.8 HP Outboard - Carburetor Fuel Problems
This is the 2nd summer for my 9.8hp Mercury Outboard.
It has serial# 6196703 there really is no "set year" when it was made according to the dealer. I've looked all over online and can't find a ser# search anywhere.
In checking with the dealer here are two different carb options (have to closer inspect tonight):
1.) Tillotson (1364-7909)
2.) Walbro (WMB-1 or WMB-3)
My problem is the boat ran decent last year. I winterized it myself and put fuel Stabil in the tank and ran it so it got into the carb. Then I put fresh gas in this spring, ran it around the lake once (15min) and started/stopped a couple times and put it away for a month. I put in 1/2 tank of gas again a month later and she wouldn't start. Upon closer examination there is a "CLEAR" gas tube on the carb and it had an air bubble in it and no gas seems to be moving up the tube when the primer bulb is pushed.
I really believe the bulb got pressurized too much which popped a diaphragm in the carb. The carb tube is CLEAR (as you can see through it) and there is a constant air bubble in there that just won't feed gas into carb. If you disconnect it, of course the primer bulb spits gas eveywhere, so that is quite fine.
I did take off the end where there is a screen on the carb, cleaned it and replaced it, still nothing. Not an easy thing to remove, not sure how I'm going to get the carb out of it quite yet, having never done it before.
Any suggestions, schematics or manuals you might have showing this inside? I've done an exhaustive search online and can't find anything.
  #2
Old June 30th, 2008, 05:35 PM
8075mercury 8075mercury is offline
Default Re: Mercury 9.8 HP Outboard - Carburetor Fuel Problems
Here is some serial number info:
http://marinshopen.se/Hj%C3%A4lpmede...6/Default.aspx
I would suggest that you get a factory service manual direct from Mercury or off ebay or a Seloc manual off ebay. I do not think I remember any "clear tubes" feeding the carb on this motor. I would start by disassembling and cleaning your carb.
Good luck, these are great little motors!
  #3
Old July 2nd, 2008, 02:15 PM
burgessm84 burgessm84 is offline
Full schematics & parts lists for both of those carbs at: http://www.crowleymarine.com/mercury_parts/297.cfm
I tried their search by serial number at: http://www.crowleymarine.com/parts.cfm and there were only 2 9.8's listed - one was international so I picked the other - it's listing both the carbs you mentioned.
I've bought water pump stuff from this web page - got it fast and their color coded parts show you how long it'll take to get. Pretty cool site.
Good luck,
Mike
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
90 HP Mercury Outboard with BAD Problems bassin_baloo Mercury & Mariner Outboards 8 October 27th, 2008 09:12 PM
Problems with 25 hp Mercury Outboard wtmf Mercury & Mariner Outboards 0 June 16th, 2007 02:32 AM
Mercury 135hp, Carburetor problems Ondo Mercury & Mariner Outboards 2 May 11th, 2007 11:28 AM
Carburetor Problems on a 50 hp Mercury (1982) kbaker7544 Mercury & Mariner Outboards 1 June 24th, 2002 03:19 PM
Carburetor and Fuel pump problems 1968 Mercury 39 clockmaker Mercury & Mariner Outboards 0 May 24th, 2002 08:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
