  #1
Old June 30th, 2008, 09:54 AM
happonen happonen is offline
Default 2005 115 yamaha 4 stroke squeaky noise
I have 2005 115 yamaha 4 stroke ,after full throttle and slowing to low rpms I hear a a chirping sound from the motor every couple of seconds then it goes away after a minute or two.The warning indicators shows nothing,the water pump is working,any ideas
  #2
Old July 1st, 2008, 12:16 AM
sdsaw sdsaw is offline
Default Re: 2005 115 yamaha 4 stroke squeaky noise
I've heard a couple of people say that it may be a dry drive shaft guide bushing that causes that (need to grease it)
Scott
__________________
"Somebody put salt in the ocean to punish us boaters"
1989 22' Bayrunner Cuddy (Aluminum)
2001 Merc. 115 Saltwater Series Fourstroke
1988 Yam. 9.9 High Thrust Fourstroke
1998 Dodge 2500/ 24V. Cummins diesel
  #3
Old July 4th, 2009, 09:34 AM
louisp louisp is offline
Hey happonen, did you ever resolve the chirping sound? I have a similar issue with a '05 F115, at first I thought I heard a squeaky belt but turns out the sound was coming from mid-section. After it warms up, it sounds like a bearing going out (or am I paranoid). I've read in this forum about plastic parts that could cause similar noises, but the metal and plastic housing in the mid-section seem hot after running- but that could be normal. Anyhow, I wasn't taking a chance and it's in the hands of Yamaha mechanics now.
  #4
Old July 8th, 2009, 10:41 AM
loyoki loyoki is offline
Don't matter, it is normal on a F115, it is just the tensioner assy (pulley to tend the belt) part 67F-11590-00-00. Just grease it with WD40.
Loïc
FRANCE
  #5
Old July 21st, 2009, 10:47 AM
Quote:
Loïc
FRANCE
There's quite a few F115's around here but so far mine is the only one with this particular noise. I had it in to the local Yamaha dealer to check it out since I just purchased it used, they said everything was fine and greased something in the mid-section while the foot was off. It ran quiet for about 20 minutes then came back. I put 6 hours on it with a heavy load (pulling 3 person tubes) this weekend and no problems except the squeal. What's aggravating is it won't make the noise till it warms up and runs under load, so I can't duplicate it in my yard. It's hard to pinpoint the seat of the noise while it's in the water, but to me I would estimate it to be the bearing located at the top of the shaft (part # 93317330U200). If that is indeed my problem, is that bearing and housing accessible with the foot off. But I 'll try the wd-40 suggestion first. Even if it's not a problem, half of my fishing is trolling and this will drive me (more) nuts.
One more question, my manufacture date says 11/05, so is this a 2005 model or 2006? The parts lookup is different for the two models. My S/N is 68V X 1059382 with a K below it, if that helps. Again, thanks for all the input.
  #6
Old July 21st, 2009, 06:50 PM
rodbolt rodbolt is offline
all the big F motors used a bushing just above the waterpump in the mid section, some times they squeak.
have the dealer check the bushing carefully,especially in salt water areas and use a lube like quicksilver special lube 101 to grease it.
DO NOT spray the tensioner with ANY oil.
if the tensioner is bad its simply bad but putting oil on a drive belt is really bad.
as far as year model is concerned yours is most likly an 06 production run, only the model number will tell me.
the 05 will have 4 alpha characters ending in D and the 06 will only have 3 alpha charaters behind the HP number.
  #7
Old July 23rd, 2009, 09:43 AM
Thanks Rodbolt, the model is F115TXR. The dealer had the foot off and lubed something, but after 4 unreturned phone calls and 3 weeks just to check this out, I would rather do it myself. I'll call them to confirm if this was the part they lubed, but if it was the fix didn't last long. When I looked on the Yamaha parts diagram, I couldn't identify the specific bushing you mention. Is this a part I can replace? I have pretty good mechanical skills and LOTS of time, just retired! Once again, many thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 2005 4 Stroke 115-Good,Bad-Opinions needed hawilson2 Yamaha & Suzuki Outboards 5 November 13th, 2007 10:13 AM
2005 115 4 stroke rob711 Mercury & Mariner Outboards 0 July 5th, 2007 12:48 PM
2005 Mercury 115 4 Stroke EFI DSavage Mercury & Mariner Outboards 10 November 1st, 2005 05:25 AM
Mercury 2005 4 stroke 115 smoking fiddleroost Mercury & Mariner Outboards 6 May 1st, 2005 05:32 AM
A squeaky noise Chuck Rowe Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 16th, 2004 07:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
