  #1
Old June 30th, 2008, 02:00 AM
19sterling 19sterling is offline
Unhappy 89 Mercury 150hp leaks from carb. when turn steering
Hi. I recently purchased a boat with a 89 Mercury outboard 150hp. Anyways I had it serviced and everything checked out great. I had taken it out to the water to use it, and realized the clamp holding the hose to primer bulb had popped off, and was leaking gas. I replaced it with a hose clamp, and no more leak... I happened to run out of gas on the water, removed the boat and went home. I then filled up the tank, but used a 25:1 ratio(which I was told was way too much oil). Anyhow, it seemed that after that, I noticed I was leaking oil/gas out of the cowls somewhere. I removed the covers and saw that it was coming from the carb. cover. I removed the cover off the carbs, and saw it was slowly coming out the barrels. I wiped it up and it stopped leaking. I left it there all day, no leak. I then turned the steering wheel and it caused the oil/gas to leak out the barrels again. What is causing this??? Also, I cannot start it do to it being flooded, but when I remove the spark plugs and shoot a little starting fluid down the cylinders, it fires right up. It idles perfect, and very responsive on the throttle. No bogging. So my concern obviously is the starting factor. Which i believe the leak is flooding the motor causing this starting problem... Please help me!!!! Also, I noticed that the bulb is no longer hard, when I squeeze it. It takes 2-3 squeezes to get it hard, and by then Ive got oil/gas coming out the barrels.
  #2
Old June 30th, 2008, 02:37 AM
jason1150 jason1150 is offline
Default Re: 89 Mercury 150hp leaks from carb. when turn steering
try tapping on the float bowls, maybe they are stuck, J
  #3
Old June 30th, 2008, 12:20 PM
would that be located on the bottom end of the carbs.?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
89 Winner Fish & Ski Leaks Donald Horne Winner Boats 2 August 21st, 2008 12:27 AM
89 Winner Fish & Ski Water leaks Donald Horne Boat Topics and Questions (not engine topics) 0 May 9th, 2007 10:40 PM
89 OMC cobra 4.3 leaks water through transom??? coffems Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 January 11th, 2007 09:37 PM
carb idle adjustments 150HP Mercury ignatz Mercury & Mariner Outboards 0 July 13th, 2003 11:25 AM
99 225 mercury, can turn flywheel one turn then it stops HELP! jsmith55 Mercury & Mariner Outboards 5 April 29th, 2003 08:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
