mercury 140hp 2006 water pump question
hkgboater
recently flushed the engine with fresh water after use, with the engine running and the muffs fitted the hose came off so no water to engine.engine proberbly ran for max 1 min at idle before I turned it off.
1.what is likelyhood of damage to the waterpump / engine?
2.what do I need to do before running it again?
hkeiner
Re: mercury 140hp 2006 water pump question
The motor probably did not overheat and is likely fine. Aside from a visual inspection of the motor for signs of melting wire and such, you can do a compression test of the cylinders for peace of mind. The impeller in the water pump, however, may have been damaged or weakened by running it dry. Even if you did a water pressure test on the cooling system and found it within specs, you can't predict how long the impeller would last if it was weakened. If it were my motor, I would replace the impeller.
Others that have actually done what you did may provide more "real-life" opinions on how likely the motor survived this experience.
