Re: water in lower unit 1975 75 hp evinrude
hi there, i have just been on a mission to fix what may be your problem, If the water isn't getting in through the filler/drain plugs or the gearcase screws then it could be this - i have a johnny 6 hp but no water in oil, all i knew was that the water pump was not working...took pump off and low and behold the alloy housing underneath the water pump was corroded. i was probably close to getting water in my oil if it hadn't been for the gasket under that part. Check it out while your down there.
ben
