Knot Waiting
- Jun 23, 2006
- 761
88 Mercury Alpha 1 off a Mercruiser 5.7 350
Somehow over the weekend I lost the ability to trim up via the trigger switch. Yet the trailer mode works fine. Any ideas? I had to run all weekend using the trailer switch to trim my drive... ghetto.
I removed the switch and found if I touch the red(power) wire to the blue(trailer) wire it runs the drive up.. all the way. If I touch the red to the green wire, it runs the drive down. Nothing happens however when the red wire is touched to the purple(manual up, I assume) wire.
Also I removed the cover to my trim sender and found the white contact disk inside broken, so it is not registering the drives position, but I dont think the sender(not the limit) has any effect on how the drive operates does it?
Anyone have this problem before, thanks for any advice you can give.
