  #1
Old June 29th, 2008, 04:42 PM
BillM2 BillM2 is offline
Default Mercury 4hp 2 stroke
I found out from a local dealer the outboard is a 1986. I may have a problem with the fuel line filter or pump. Where can I see a diagram of this engine as I need to find the choke arm which has broken off?
>> I have a 4hp Merc 2 stroke serial #A907218 and am looking for information on this outboard. I am trying to start it and have only been successful at getting it to partially start by spraying starting fluid into the spark plug hole. As soon as that is burned, the engine shuts off. The primer bulb is firm and gas seems to be getting to the engine.
Along the way I also broke the choke arm when replacing the shroud. Where can I get that part and what's required to replace it. It looks pretty daunting.
Many thanks for your help!
__________________
1988 Sea Ray 21CC Seville, 4.3 liter, Alpha One, 14/21 Merc Prop
Last edited by BillM2 : June 30th, 2008 at 02:46 PM. Reason: more information to provide
  #2
Old July 26th, 2008, 12:14 PM
Default Re: Mercury 4hp 2 stroke
I was able to purchase the choke linkage. Now, I have removed the fuel filter but cannot remove the carb because the old linkage is in the way and doesn't give enough room to lift the carb up and out. How do I remove the choke arm? It's a 1986 4hp Mercury. There doesn't seem to be any screw holding the outer choke knob in place....
The filter seemed clean, but noticed some blackishness on the jet to the carb. Could this be why it wasn't firing (it would run if I put ether into the spark plug hole for about 3 secs until it burned out)????
__________________
  #3
Old July 26th, 2008, 03:51 PM
I fixed the choke arm lever, but am not getting fuel to the carb. I inspected the fuel filter, which had no debris in it. I also noticed that the carb's jet was plugged and sprayed carb cleaner on it and depressed the gunk with a needle. How do I determine what the problem is with the fuel? When I put starting fluid in the carb, the engine starts right up, pumps water and shuts down after burning off the starting fluid.
Bill
__________________
  #4
Old August 1st, 2008, 01:49 PM
mooregecko mooregecko is offline
Get a manual and look up fuel delivery. There is a host of issues that should be diagnosed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starting Mercury 4hp-4 stroke soh_2 Mercury & Mariner Outboards 1 August 12th, 2007 03:38 PM
Mercury 4-Stroke (4HP) Shift Arm fishingguy Mercury & Mariner Outboards 0 April 17th, 2007 04:02 PM
Mercury 4HP 2 stroke impeller change RSCaptain Mercury & Mariner Outboards 5 June 3rd, 2006 12:21 PM
1978 Mercury 4HP 2-stroke impeller change ant.mass Mercury & Mariner Outboards 1 June 3rd, 2006 11:23 AM
Mercury 4HP 4 Stroke Air Leak ChrisE Mercury & Mariner Outboards 1 November 10th, 2002 06:25 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
