I have a 1997 Capri 1950 with a 3.0 LX engine. I am not positive I have the same bilge pump but would assume so. It is an orange pump with a black base directly under the engine. My pump was not working either and I was determined to fix it. The black base has a molded in retainer - kind of like a slit in the plastic of the base. You have to get your fingernail in the slit and pull out slightly this will release the pump from the base. You have to slightly twist and pull up on the pump as you have the slit in the base pulled out and the pump will release from the base. I initially pulled the drain hose off the outlet but I don't think it is neccesary to do that - I figured that out once I had the pump out. Once the pump was out of the base, I found a piece of plastic wire tie jammed between the base and the impeller blade, I removed the piece of wire tie cleaned the surfaces and the pump worked again. Hope this helps - for sure not an easy job - kinda have to be a contortionist. To reinstall the pump, you just have to push it back into place, that part is easy.
