After doing much reading here on these tabs I went and purchased a set. After installing and testing I found that both "shocks" broke free from the mount at the bottom of the tab. I am curious if anyone else has had this issue? The bottom of the "shock" has a plastic screw that screws into the mounting bracket which in turn gets mounted onto the tab by a pin. It broke free from where that plastic screw is. I had them in there default position which was the middle hole. Since than I have tried emailing nauticus but have not received any responses(3 weeks :/ ) so Im trying here. I have also re-screwed the shock back to its mounting bracket and changed it to the outermost hole. After taking it out again they did remain intact but that is not how it should be. I should be able to adjust it to any hole without them breaking free. I followed the instructions and triple checked all my work I cannot see where I may have caused this problem. Any advice?
