1989 V6 150 Evinrude ignition probs
I am having some ignition problems with this motor, here is what Ive done, replaced the powerpack with a new OEM pack. Stator has good voltage and passes resistance tests,
The timer base is what i am questioning, the resistance on the timer base from the black/white wire to the white wire starts out reading 11 ohms and then slowly and steadily climbs , I have no voltage out of the wires from the base (using a low peak DVA meter) .
The reason I started testing the ignition is because I only had spark on two cylinders on the left bank and now I dont have any spark at all, I have worked on quite a few outboards and have never replaced the timer base. Just looking for some tell tale signs of a bad timer base. Thanks for any info in advance.
Stew
