  #1
Old June 28th, 2008, 07:16 PM
marklake marklake is offline
Default 2000 Yamaha 150 2Stroke Carb Stalling
I just bought a boat with a 2000 Yamaha 150 2stroke carb with 235 hours on it. The previous owner took great care of her.
My question is she is running rough sometimes at idle and the idle is not reliable. She wants to stall and does sometimes.
The fuel has been in her about 8 months. Could stale gas be a problem?
Thank you:-)
Also, any owners who have one I would love to hear your experience.
  #2
Old June 29th, 2008, 10:56 AM
Default Re: 2000 Yamaha 150 2Stroke Carb Stalling
anybody with ideas or personal ownership knowledge?
thanks
  #3
Old June 29th, 2008, 12:59 PM
DC20's Avatar
DC20 DC20 is offline
I would drain out all the old fuel, replace all fuel filters and rebuild the carbs.
  #4
Old June 29th, 2008, 01:08 PM
erniefish erniefish is offline
fuel probably,do you have ethanol/gas? replace fuel filter, sample gas, replace if in doubt, may have to do carbs, pretty simple,i just did my 2004 150 clean every possible orfice in the carbs,pay attention to screws on top of carbs, (if so equiped) screw in lightly ,counting the number of turns, do not forget to hook up the oil control arm on the side of the motor, sinc and link and you should be fine, also check fuel pumps to make sure they did not dry rot,back off bolts on pump and squeeze primer ball, if fuel leaks out of pump near motor/gasket than replace, good luck these are all very simple steps, and can save you some$$$$,
  #5
Old July 28th, 2009, 05:47 PM
Rdude Rdude is offline
Disconnect fuel line at primer bulb and run off external 5 gallon tank. If it run good then drain and inspect the fuel system and your fixed. If not you must do that and more by completing a fuel systom diagnostic. Start with filter at engine (clean), then carbs (clean), and lastly fuel pumps (replace).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
99 Yamaha 115 2stroke-Carb Starting/Idle issue MacGyver_74 Yamaha & Suzuki Outboards 4 June 9th, 2007 02:43 PM
2000 Yamaha 150 hp 2stroke no top end ermess Yamaha & Suzuki Outboards 13 March 19th, 2006 03:00 PM
repairing or taking carb out of 15 horse yamaha 2stroke tamster61 Yamaha & Suzuki Outboards 3 May 18th, 2005 06:37 PM
repairing or taking carb out of 15 horse yamaha 2stroke tamster61 Non-Repair Outboard Discussions 1 May 17th, 2005 08:05 PM
2000 Yamaha HPDI Stalling above 2000rpm Fishbreath Yamaha & Suzuki Outboards 1 May 31st, 2003 03:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
