agutowski3388
- Apr 8, 2008
- 22
I have a 1880 Pound 17ft 1987 Searay. I went to repack the bearings and there shot. When it put it back together it just makes a loud griding sound. Feelings and Inspecting the bearings you can tell there old (20 years old) and should be replaced. I was just going to buy two entirely new hubs for the trailer which come with bearings, seals, and races. My Questions is.
Do i need the Hub Assembly for 2000lb axle or should i get the hub assembly for the 3500 lb axle???? The Numbers for the Hub is 5 on 4-1/2 and and L44649 bearings.
I figured on buying new hubs cause it would be alot easier and faster to just put new ones on then replacing the races in the exsisting hubs. Is that a good reason?? the different in price is not much at all.
