  #1
Old June 27th, 2008, 10:46 PM
fishingfinn fishingfinn is offline
Question 1996 40 hp Evinrude-primer fuse location?
Hi, I recently bought a used boat with a 1996 40 hp Evinrude (mod. E40TLEDS)
It was starting fine, but now the electric primer does not click or prime the motor when key is pushed in. Is there a fuse for this circuit? If so, where is it located?
It starts if I move the red primer lever to manual prime. Thanks in advance for your help. Don
  #2
Old June 28th, 2008, 06:29 AM
bgbass.1 bgbass.1 is offline
Default Re: 1996 40 hp Evinrude-primer fuse location?
There is no fuse either rebuild it or replace
  #3
Old June 28th, 2008, 09:30 AM
Silvertip Silvertip is offline
While it's true there is no fuse, don't be in a rush to replace or rebuild it. There are a couple of things to check before doing that. Wiring and ignition switch are two. Disconnect the wire to the solenoid. Using a test light or voltmeter, turn the key on and push the key in while checking for voltage at the wire. Yes - go to next step. No - you have a wiring issue.
If you have power at the wire, use a short jumper wire between the solenoid wire and a +12V source (like the starter solenoid). If the solenoid clicks, its ok. If not -- now replace it. You can also verify if its coil is open with an ohm meter.
  #4
Old June 28th, 2008, 10:25 AM
Thanks bgbass.1 and silvertip. I will check things out as suggested.
  #5
Old June 28th, 2008, 10:57 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
the key has to be in the "on" position for it to work.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 40 HP, primer and hoses halmc Johnson & Evinrude Outboards 0 April 14th, 2008 05:15 PM
1991 40 hp Evinrude - location of neutral switch tuckatucker Johnson & Evinrude Outboards 4 August 17th, 2007 04:08 PM
Need help with locating a primer solenoid for 40 HP evinrude tschuy Johnson & Evinrude Outboards 1 June 12th, 2005 02:50 PM
1996 40 hp evinrude franger Johnson & Evinrude Outboards 3 April 11th, 2005 05:29 PM
fuse problem 89' evinrude 40 HP shmeckle Johnson & Evinrude Outboards 1 April 8th, 2003 08:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
