  #1
Old June 27th, 2008, 07:02 PM
orlandoscout orlandoscout is offline
Default 96 Yamaha Steering Cable
First I must disclaim that I know very little about outboard repairs.
Recently I took my Scout out and as I turned the boat I noticed it was difficult to steer, I forced the steering as I made a sharp turn and the steering wheel broke off. I assume that the problem lies in the steering cable, therefore I have purchased a new teleflex steering cable, and helm. I attempted to disconnect the cable/rod off the motor however came across some problems. I loosened the bolts at each end of the cable/rod and attempted to pull the cable/rod out of the housing. (see photos at http://www.kodakgallery.com/I.jsp?c=...caleid=en_ US ). I was able to pull the cable on the left side of the motor(looking at the motor from inside the boat) however nothing happened to the rod on the right. I hoped that the rod was 1 piece that extended from the left of the motor to the right, it appears as though they are not connected. I then took a hammer and hit the rod on the right side from left to right. The rod moved approx. 2 inches however nothing happend on the left side of the motor. I am not sure if the rod should be driven through the housing completely. If so please provide recco for how to drive it all the way through to the other side.
  #2
Old June 27th, 2008, 11:39 PM
Inducted Inducted is offline
Default Re: 96 Yamaha Steering Cable
The rod is actually one unit with two pieces, one riding inside of the other. Continue hammering it out. Try not to mushroom the end from hammering. Once the rod recesses inside the tube you will need a long punch to hammer it all the way out. Use lots of penetrating oil. Make sure the cable lock nut is completely free. From your picture it looked like it was. Try to clean out as much junk as possible from steering tube before inserting new teleflex set up.
  #3
Old June 28th, 2008, 04:03 PM
mikesea mikesea is offline
Get a pair of vice grips,a good pair.Remove the steering bar out of the cable hole.You will see the area ,about an inch or two toward the motor from the hole,put you vice grips on there and try and turn the cable,both ways,if the vice grips dont work get a pipe wrench.Once it loosens ,try and pull out from other side,if it gets stuck in the motor tap it through while someone pulls the other side,dont hit the end of the cable with the hole,without putting a bolt in the hole,it WILL mushroom,if you cant turn it with wrench you may need to use heat on the eng.tube.But its dangerous.Get back with your progression after the vice grip/wrenck try
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
CABLE BUDDY™ Steering Cable Lubrication System????? Pas Bon Boat Topics and Questions (not engine topics) 2 May 11th, 2008 05:09 PM
Need help hooking up the steering wheel cable & throttle cable (25 horse Mariner) 123Bill Mercury & Mariner Outboards 1 March 26th, 2008 09:31 PM
replace steering cable on yamaha 90hp at hiker Yamaha & Suzuki Outboards 1 May 21st, 2006 04:57 PM
Safe to run twin cable steering w/ one cable? DocBob Boat Topics and Questions (not engine topics) 3 August 6th, 2003 06:43 AM
70 hp yamaha steering cable problem pcarter Yamaha & Suzuki Outboards 6 August 26th, 2002 01:00 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
