Mercruiser 140 wont shift
trevguy
Hi everyone. I don't know much about boats but I am looking at one to buy. The problem is that it does not seem to shift into forward or reverse. All it does is rev the engine. Any suggestions? We pulled the boat out of the water and pulled the drain bolt for the gear oil, It had a lot of water in it. The bolt was not very tight as well. Any suggestions?
Don S
Re: Mercruiser 140 wont shift
Free would be way to expensive. Probably looking at a minimum of $2000 worth of inexpensive aftermarket parts to fix it. Not counting any labor you have to do.
ziggy
yep, if yer lookin to buy, and that's the one yer lookin at and ya ain't bought it yet. don't, dons ain't kiddin..... ya'd be in for some serious work + $'s....... at least buy one that shifts. ya'll be money ahead......
CharlieB
It all depends on the value of the boat, what's wrong, and what it's going to take to fix it.
You can get a complete SEI outdrive, with labor and a decent once over to set you back 2 thousand or more if they find much else wrong.
It had better be in very nice shape or I'd pass.
Ayuh,....
With the # of Used boats on the market,.....
That's Not the 1 you want to Buy.......
Wotknot
Run, that is a pos.
UHHHHH HUHHHHH ............ I second that motion. If you're looking to learn about boats by wrenching on one from the start, then by all means, go for it. However, if you're wanting to go boating from the start, then RUN away from this one.
trevguy
Thanks guys. I was told to check the Throttle only button. Other than that I am prob going to pass on this one.
trevguy
By the way Bond-o,,, your avatar looks like it might be a little low on oil...LOL
Don S
That won't make it shift, it just makes the control operate the throttle only and not the shift.
trevguy
Even if the button is stuck on??? I guess you guys know better tho. I think I will stay away from it.
Don S
You never said the button was stuck on, we aren't mind readers here.
trevguy
No,,, sorry. I don't really know much about it. I was just told that it could be stuck on. i didn't mean any thing bad. I appreciate all the advise I can get.:)
Ayuh,.... That Alone, is reason enough to Run from the Deal....
BAYLINER185
yes, if the throttle button is stuck in then yes the boat wont shif and just ref the motor in F or R.
If you cant press the button in then theres a problem. But the water in the drive is bad enough. How long was there water in the drive?
It could be just a loose oil fill screw but then again who knows. when you go to look at a boat to buy it should be in workign order not need fixing from the get go.
