This is what repairs ive made I need advice what else to do.Rebuilt carbs, set floats parellel which seloc stated. All new fuel lines.... Properly gapped spark plugs....Checked compression. Here are the readings #1(119)....#2(120)....#3(122). I also did a spark test all three fine with plugs out checked them at 7/16, but here is the puzzler.... when idling if i pull #2 or#3 plug wire it has no effect but when i pull #1 spark plug wire it stalls. I also squirted with spray gun fuel in carburetor throats this is what happens..... #1 with fuel wants to choke like flooding... #2 revs up..... #3 revs just a little. Parts store said maybe it's the power pack. I have one but if i try it i can't return it. What happens when im out in lake it idles but just dies when put in gear and throttled up.
Getting desperate thanks in advance 4 any help.
