  #1
Old June 25th, 2008, 03:39 PM
90Proline21 90Proline21 is offline
Default Oil Leaking Out Of Carb???? 89 yamaha excel
Can anyone help me with a problem with my motor. its a 89 yamaha excel v6. There is oil leaking out of my middle left carb. It leaks when the motor is tilted and does not matter whether or not it's running, it still will leak out. This just started happening after I ran it on friday. Is there a valve or something that is in the oil pump that could be stuck open. I dont know to much about motors. Please help.
  #2
Old July 12th, 2008, 06:51 PM
Parkhil2 Parkhil2 is offline
Default Re: Oil Leaking Out Of Carb???? 89 yamaha excel
I have a 87 V6 with the same problem? Anyone have any suggestions? Keep boat in water and it is making a mess?
  #3
Old July 12th, 2008, 07:20 PM
douglloyd douglloyd is offline
I had that problem many moons ago it was some one way valves in the oil lines.
Check the parts section to see if it applies to your particular motor.
They are between the oil pump and the carb about halfway to the carb.
Good Luck!
  #4
Old July 13th, 2008, 12:08 PM
rodbolt rodbolt is offline
89 should have the old style pump with 6 nipples pointing up. if its been updated it will have 6 nipples,3 on each side, in a horizontal plane.
the old pump has builtin check valves and the later one inline check valves.
I have seen inline check valves added to the old style pumps. just remember the pump squirts in pairs and you will need to add the inline check valves in pairs.
eithet that or replace the pump as nessasary.
but first we need to identify which setup your running.
  #5
Old July 13th, 2008, 01:14 PM
drewmitch44's Avatar
drewmitch44 drewmitch44 is offline
Does that apply in identifying oil pumps for other year/models of yamaha? I have those inlind check valves on my V4, so does that mean that i have the newer style oil pump? Its a 86 or 87(?) 115ETLJ. Thanks rod you are the man in here!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
YAMAHA 89 225 excel t/t problem SALTNECK Yamaha & Suzuki Outboards 2 May 21st, 2007 10:51 AM
1989 Yamaha Excel Carb Problem? Ray Neudecker Yamaha & Suzuki Outboards 2 July 11th, 2006 10:01 AM
1989 225 excel yamaha retro oil pump jk1162 Yamaha & Suzuki Outboards 15 July 13th, 2005 12:35 PM
89 225 Yamaha V6 Excel Overheating Key Largo Yamaha & Suzuki Outboards 14 March 24th, 2005 07:01 PM
89' Yamaha V6 Excel XF Overheating Shaffer_R357 Yamaha & Suzuki Outboards 1 August 8th, 2003 12:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
