Quote:
Originally Posted by northwoodsPT
If the steering is tight with the engine disconnected, does that mean that the steering cable itself is the problem. If it steers easily is that the case where you have to use some sort of greese to lubricate where it goes into the engine. I have been doing some research on some other posts about this topic...can you disconnect the cable from the engine without taking the engine off the transom?
Thanks for your response
There are so many variables that if I tried to shotgun all the possibilities, I'd be here all day, and forget the point you need touched anyway.
Do it step by step.
First, verify that it is rack, vs drum. The difference is obvious by the descriptive name.
Then, disconnect it at the steering link from the cable to the steering arm on the motor. See where it's tight.
If it's the motor, one of 2 bushings has frozen and isn't taking grease. One grease fitting on the mid services them both, so it could be a problem to get lube into the stiff one.
If it's the steering, it's likely the cable, but it could be just crud in the tilt tube jamming the piston. Either way you have to remove the cable from the engine to fix it. It's stiff, and you'd likely have to unbolt the engine and hang it on a hoist to pull the cable out.
A quick inspection of the cable where it bends sharply beside the helm, and also at the motor well may reveal a rupture that will end your search without much work, except for replacement.
hope it helps
John
