Re: No water coming out pee whole
First off, mine only pees in the lake! Will not pee on muffs or a barrel dont know why, it just want! So here are some things to check:
1.) Make sure no insects have made some unwanted homes in water passages.
2.) Make sure impellor is good! Better yet, change it out if you havent!
3.) Make sure your t-stat is in good shape! And not stucked closed!
4.) Test t-stat by putting it into water and turn the stove on and verify that it opens at its correct temp.
5.) Make sure gaskets under water pump are in good condition! If not it will suck air!
6.) Check ALL hoses for debris that might have built up and used compressed air to clean them out!
7.) MAKE REALLY SURE that the tube that connects the water pump housing is intact with the throat that goes up to your t-stat!
8.) HAVE PATIENCE! youll figure it out!!
GOOD LUCK!
