Re: Testing the stator on 97 Mercury Engine
Most of the 20HP that came with a factory installed electric start have a stator for charging the battery, check your engine for a yellow and gray wire coming from underneath the flywheel to a small rectifier. If you have them you have a rectifier. they should test 65 ohms wire to wire and open to ground. The problem is ussually the rectifier if the system don't charge.
