Re: R & R impeller, 86 alpha one lower unit
Should be easy to do. I found it very easy the 1st time I did my 1st outboard 10 years ago and found the process identical to my 1st Alpha Drive.
Just remember the shift shaft / shoe when you reinstall the lower unit. The lower may seem not to want to suck back up on the upper and youll be so close but yet so far from getting it on. It the shift shoe holding you up.
Its a fun little job!
