My 2001 Yamaha 150 Z150TXRZ won't start. The engine ran fine last year and now after winter storage won't start. I drained the low pressure reservoir for storage last year. The engine will fire as if starting and run for a few seconds with gas sprayed into the intake. The low pressure pump is pumping as when I disconect the hose to the High pressure pump a stream comes out, also a stream when I depress the tire valve test port, although not with any great pressure. I tried hooking the tank gas line directly to the High Pressure intake and by squesszing the bulb tried to start it but same thing. Do I have a HP pump problem? Any other trouble shooting ideas?
