Help!... I just rewired my boat and can't get either of my 1971 50hp Evinrude's to fire. The are both suffering from the same issue with no spark.
The boat has selectric shift for each engine and there seems to be no neutral on either engine.
Both engines crank well and will shift from forward to reverse, and the electric choke is fine...... but no spark.
It seems to be stuck in gear, as I can't turn prop freely with ignition switch on or off
Am I missing something easy? b/c I had all wiring off is there something manual that needs to be done to get back to neural?
Also, is there a "neutral safety switch" thats exists?
