14' Aluminum Boat Paints
TheCompound
What paints are there to use?
Where can a guy get them?
Are there any spray primes and paints, I could use?
Thanks,
-TheCompound
fishie
Re: 14' Aluminum Boat Paints
roll n tip with rustoleum and penetrol(its a type of additive for oil based paints) provides a smooth finish.
cprince
Roll I would think is simply using a roller.. but what is "Tip"?
TIA!
tashasdaddy
search roll & tip . it is a process of using a fine roller and brush, works very. this is a r & t job, with rustoleum.
fishie
Hey tashadaddy, do you know if a clear coat was put on that boat? I'm trying to find one to put on my boat after I paint it...Sorry for the hijack.
tashasdaddy
no clear coat. i don't use it. the deck was satin finish, as i don't want the glare from the deck. the hull is high gloss. i don't use clear coat, as it make it harder to touch up when it get scratched. as it is a ding is corrected in 5 minutes.
