I Have a f100 2001 that has problem
going into reverse it started 2 years ago
some times it would grind when going reverse
allmost like you are putting it in reverse to slow and you get that grinding
but thats not the case.
this spring in the driveway it would go in forward/reverse running with no problem.
now the baot is at the lake and no reverse. it will just grind and not go in.
but after you go forward at sppeed and slow down like to dock the boat
it will go in reverse just fine no grinding just like going in forward.
