Re: force lower unit leaking lube from the shift screw
Tighten then test it if you need to replace the seal.Then get the seal first!!!Any place that sells Merc stuff will have that or can get it.
When replacing it put the motor in neutral then remove the screw and replace as sonn as you can.
DO NOT MOVE ANYTHING!!!!!!! Don't touch the prop.Don't turn the motor over.Don't move the prop shaft.
It will mis-align the work and then it will cost$$$$ Jerry
