jefisherjr
- Jan 24, 2008
- 19
I have a carburated 1994 225. Engine starts fine, but will not shut down when ignition is switched to off. I replaced the ignition switch with a new OEM switch. Still won't stop. Checked wiring and connections from switch to motor, all looks fine. When I turn the switch to stop, the rpms drop slightly. If I bump the thottle/shifter a few times to forward and back to neutral I can get the motor to die. Any ideas? Thanks.
