Re: 1968 55hp Evinrude impeller change
Only that you have to remove the trim tab and the hidden bolt above it.
EDIT: Oh, and when you get the lower unit off, look up on the water tubes and you will find two plastic tubes. Pull them off the tubes and stick them in the recesses in the water pump cover. They are to guide the tubes during reasembly when you can't see what you are doing up in there. Oil the tube grommets so they slip in easy.
Reason: more..
