Re: Mercury 4-stroke carb sync
I don't know much about carb-related issues on marine engines but if it's anything close to 4stroke, 4cylinder, carbed motorcycle engines, here's what I can tell you:
- Improper carb-syncing affects mostly start-up and low-rpm operation. At WOT you won't tell the difference between proper and improper syncing.
- The dealer you spoke to probably didn't know much about syncing since he told you his procedure of adjusting the air/fuel mixture. It has nothing to do with syncing.
- Synchronizing the carbs involves adjusting the throttle on every carb so that the butterflies all open and close symultaneously, thus taking in the same amount of air/fuel on all 4.
- It takes a 4port sync-tool (vacuum reader) to synchronize your carbs all at once easily. A 2port could do it as well, but it's more of a hassle to adjust 1-2, then 3-4 and then 1-2 to 3-4.
- Other than the sync-tool, you need the proper adapters to connect to your vacuum holes on the block. Your manual should be able to tell you where those ports are and what size adapter it takes to connect the sync-tool.
Hope this helps
Edit: It takes a 4port sync-tool if you have 4carbs (one per cylinder). If you only have 2 carbs, a 2port is enough.
