Re: Help! Mariner cooling?
Arnie, Is that motor a v6? If so, the telltales do not put out any water until the thermostat opens. There should be a hose connected to the center of the cylinder heads, behind the flywheel. This is the recirculation hose. This one will have good pressure and volume if the pump is good.
Also, when I start up my '93 135V6, it sucks all of the water out of the muffs, eventhough I have the water turned full on.
