flabeachbum
- May 21, 2008
- 4
We have a 1996 Evinrude SPL 115 (Model # E115TSLEUA) pushing a 17' Sunbird Bowrider around the Tampa Bay, Florida area.
My main concern is the hot light.
We have putted around quite a bit (idle & just above), sometimes for extended periods (over an hour) - no problem. Even relatively cold, if we push the throttle forward enough to put her on plane, in less than a minute the "Hot" light comes on. Back off the throttle (off-plane), a minute or two later the "Hot" light goes off. Tampa Bay waters are warm, but this is ridiculous!
Pee-stream never fails with the muffs, but I haven't checked the pee or temp while on-plane. Next time we go out I'm putting a cup on a stick and checking it that way.
Normally, I would think the previous owner fouled-up the wiring to the indicator light, as it certainly would NOT be the first time. However, this seems to be a recurring and predictable symptom, one worth looking into.
Throttle position doesn?t seem to matter too much ? anything better than barely on-plane is enough to get the nasty red light. Slower speeds take a little longer (like 3 minutes), pushing to full throttle gets the light very quickly (like 30 seconds). Still runs great at any speed, regardless of that pesky little light.
We've been out very regularly since we bought her 2 months ago, but I know that we're going to be out even more this summer, and I need the know the motor isn't going to overheat and seize while we're out fishing or skiing.
My only other complaint has to be pretty common - she starts right up at home, but at the boat launch she always argues. I chalk that up to the luck of the Irish.
Thanks in advance for any and all advice!
flabeachbum
flabeachbum
