I bought a PT&T unit to install on my motor...(IT did not have one originally)...! What does one do in regards to the gear engagement rod that runs from the engine locking bracket down into the gear case? I may need to explain a little better for lack of correct terminology as to the names of these particular parts! Im guessing this rod is to ensure the motor is locked in place before allowing the motor to be put in reverse gear?
