Kerchak215
- May 23, 2008
- 2
Pardon the ignorance, as I am new to boating and boat motors. I have recently acquired, what I am guessing, is an 80's vintage Johnson 15HP on a 14' boat. I believe the motor has very low hours, as you can virtually eat off the motor when the cover is removed. I went to winterize the thing last fall. The boat had not seen water for about two years. I flushed the fuel system and replaced it with fresh pre-mix (100:1, as advertised on the side of the motor). After launching and pressurizing the fuel system, the motor fired and ran great for about five minutes, then started sputtering and then died. I can get it running, but I gotta continually horse the choke and throttle. There appears to be no air filter to change, and new plugs made no improvement. I have heard through friends that there is a valve on the top of the fuel tank that must be opened after pressurizing. Is this true, or do I need to take this puppy in for a check up?
