  #1
Old June 24th, 2002, 01:03 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Paddlewheel Speedo on Pontoon
Hi All, I just aquired a different pontoon boat and have a Humminbird Fish Finder w/ Speed & Temp probes. The speedo uses a paddlewheel type pick-up. On my old toon, I mounted the transducer on the bracket on the starboard side and just screwed the paddlewheel into the port toon a little left off center to avoid getting a false reading from the flow of water of the bottom of the log. This time I went ahead and mounted both of them on the same bracket on the right side and the speed and distance reading are way off! I think the tranducer is messing with the flow to the paddlewheel! Any suggestions as how to mount the paddlewheel or where? The way I had it on my old boat worked fine, right on the money for speed and distance! I'm sure having it right next to the transducer, not to mention directly under the log where I'm getting turbulant water flow, is the culprit! Any help would be appreciated! Thanks, Rick
__________________
Rick
"Boating is Life...All the rest is just Details"
  #2
Old June 24th, 2002, 08:32 PM
FlyBoyMark FlyBoyMark is offline
Ensign
Default Re: Paddlewheel Speedo on Pontoon
Paddle wheel should be mounted on exactly the bottom of the bracket by itself. You will get erronious readings because of accelerated flow of water around the float(pontoon) because the water has to move out of the way to allow the pontoon to move forward. Any other devices in the proximity will aggravate this phenomenom because it will accelerate the water further for it to move around the object it is displacing. (hydrodynamics 101 ) There is still an error on the bottom but usually only about 1 to 3 MPH.
  #3
Old June 25th, 2002, 05:36 AM
FlyBoyMark, Thanks for the info! I just did'nt know if the pick-up had to be mounted to the side of the log to avoid the turbulance that occurs from the log. I can only guess that by mounting it right next to the transducer, is throwing my reading off so far(About 7 MPH). I really am not so concerned about the speed part, as I am the distance reading being accurate, which of course, also depends on the speedo be close to correct! I guess my best bet would be to have another bracket welded onto the left toon and mount the pick-up there! Thanks, Rick
__________________
Rick
  #4
Old June 25th, 2002, 08:26 AM
Ensign
Some models of sonar have a correction item in the menue to calibrate this speed difference. My Eagle Accura 240 does....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Speedo?Don't need no stinking speedo! BWRex Mercury & Mariner Outboards 3 June 6th, 2005 07:45 PM
Lowrance speedometer not working. Paddlewheel the problem?? patrolcarr Electrics, Electronics and Trolling Motors 1 August 14th, 2003 07:28 AM
paddlewheel river boat- build one? mid life crisis Boat Restoration and Building 15 July 18th, 2002 03:55 PM
Paddlewheel Speedo on Pontoon rickdb1boat Non-Repair Outboard Discussions 3 June 25th, 2002 08:26 AM
Paddewheel speedo on pontoon rickdb1boat Non-Repair Outboard Discussions 0 June 24th, 2002 01:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
