So i put my outdrive back together after replacing the impeller. I made a quick pressure checker from a tire pump with a psi gauge on it. Hooked it up to the bottom of the outdrive in the drain hole and started pumping. Well i didn't pump too much, when i noticed i forgot to put the res. cap back on.
So my question: I screwed the cap back on and pumped a couple times. I could see the resivour pumping up and bulging out, but the gauge was not moving. I gave it a couple more pumps and stopped (because i didn't want to break anything). I slowly turned the cap off and it sounded like a really big pop can.
Is this normal, and will it hurt the resivour (sp). I didn't want to keep pumping because i am not even sure the gauge is working. It sure seemed like it built up a lot of pressure inside the unit, but i am unsure of where to go from here.
Thoughts?
Thanks,
Dean
95 mer alpha 1 gen 2.
Thoughts?
Thanks,
Dean
