jeremy5780
- May 8, 2008
- 147
so i got a 90 hp block not sure of the year i got this number off the top of the block on the freeze plug R8551669 i am gonna put it on a 1998 115 crossflow midsection i looked at both blocks where they mount to the mid section they are identical so i was wondering can i use the heads off the 115 on the 90 I had the 90 block bored 20 over on all 4 cylinders. Also the guy at the machine shop said the two studs that align the two halfs of the block up where tappred i have no clue what he ment by that? Do you? Also one of the cyliders had water in it and the reeds have a little surface rust on them can i clean them or do i need to replace them?
