  #1
Old June 18th, 2008, 03:46 PM
Riecus Riecus is offline
Default engine problems for a 1988 90hp mariner
Okay I ordered the carb kit and it came in today. I pulled on of the carbs off and it is clean enough to eat off of yet the first 4 spark plugs are black and they are brand new. I only ran the boat once on them. The 5th and 6th plugs are clean. What else could be causing the problem? The boat will not idle long and when u put it in gear it dies. I just can't figure out why 4 of the 6 plugs are black if it is not the carb.
  #2
Old June 18th, 2008, 05:47 PM
gregpro50 gregpro50 is offline
Default Re: engine problems for a 1988 90hp mariner
So did you rebuild the carbs or not? Many times the small orifaces get plugged up with junk while the rest of the inside looks clean. Is the spark good on those 4 cyls that are fouling?
__________________
'80 Glastron GT-150. Mercury 115
'04 Bass Tracker Pro-Team 175. Mercury 60
  #3
Old June 18th, 2008, 10:37 PM
No i did not rebuild the carbs. I figured that if the inside was not gunked then it would not cause that much gunk to build up on the plugs. that is a lot of gunk for just a small ore face to be clogged. When you pull the first 4 plugs there is a bit of oil on the threads an inside looks pretty black. any thoughts on that
  #4
Old June 19th, 2008, 12:04 AM
j_martin j_martin is offline
Have you checked the obvious items? Fuel pump with a leaking diaphragm, (there would be fuel in the pulse line where it shouldn't be) and a leaking enricher valve. (always partly choked.)
Is there good fire on the fouling plugs. The question needs to be answered to decide what else to do?
By the way, a clogged idle air passage would flood out that cylinder at idle. Unlikely to have 4, though.
hope it helps
John
  #5
Have you checked the obvious items? Fuel pump with a leaking diaphragm, (there would be fuel in the pulse line where it shouldn't be) and a leaking enricher valve. (always partly choked.) You can check that out by pinching off the enricher line with a hemostat after it's started.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 90hp Mariner idle problems Riecus Mercury & Mariner Outboards 5 June 12th, 2008 09:47 PM
1988 - 90HP 3 cylinder Mariner - Fuel leaking frednick1 Mercury & Mariner Outboards 2 November 11th, 2007 05:37 PM
Mariner 90hp flywheel/starter problems craigie Mercury & Mariner Outboards 3 July 7th, 2007 12:14 AM
1988 Mariner 8Hp-Carburator/Choke Problems frednick1 Mercury & Mariner Outboards 8 July 1st, 2007 08:48 AM
New here.. Soon to rebuild Engine 90Hp 1988 Chesapeake Explorer Johnson & Evinrude Outboards 9 August 28th, 2004 08:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
