  #1
Old June 18th, 2008, 02:16 PM
fishdog4449's Avatar
fishdog4449 fishdog4449 is offline
Default '74 Mercury 1150 reed cages yamabond repair
Hey guys!
Yet another question for all you Merc Gurus!
While I have the beast on the workbench with powerhead off, I want to make sure everything on the motor is in great condition. The motor ran before, but as you may have seen from my other post, she was gettin a little water in number 3 so I'm replacing water jacket and exhaust cover gaskets.
However, when the motor did run it took lots of effort to start, even after the fuel system rebuild. I had heard on another post that sometimes these inlines can be made to start like fuel injected motors if the reed cages are sealed to the case with yamabond. Is this a fact, if so how difficult of a repair would this be?
I would like to get this ol inline as reliable and good running as possible as I intend to keep her for a while.
thanks in advance guys!
__________________
1972 Macgregor 25'
1981 Glassmaster 17 '76 Mercury 1150 tower of power
  #2
Old June 18th, 2008, 07:38 PM
Laddies Laddies is offline
Default Re: '74 Mercury 1150 reed cages yamabond repair
It wouldn't hurt anything, we put 514 on our reed blocks for our racing engines not to prevent leakage but to steady them at high RPMs because the reed stops are cheated open as far as possible. I think as far as helping the engine startup if all the reeds are seated on the block properly thats about all you can do. Someone telling yamabonds will help startup I think was smelling the stuff to long.
  #3
Old June 18th, 2008, 09:27 PM
thanks laddies!!
I originally saw it on another post, which I now can't find, but what you said may be true
Well the motor runs fine on muffs and idles smooth (albeit have not done a boat test yet) the only problem is the hard starting. Other than that the motor has no issues, but if I decided to do it anyway, what is involved about getting to the reeds?
I've been doing some more research on the forum and found that many people have inlines which are hard to start even if they are in great condition. I just have a hard time believing that nothing could be wrong with the motor, yet it takes that much effort to start.
__________________
1972 Macgregor 25'
  #4
Old June 18th, 2008, 09:56 PM
gregpro50 gregpro50 is offline
Mine starts hard when cold but once you've started it for the first time of the day it will start like it's fuel injected after that, even if it sits for a few hours. Both of the ones I have owned have been that way. I think these I6 Mercs start better and run smoother than any of the OMC's that I've owned.
__________________
'80 Glastron GT-150. Mercury 115
'04 Bass Tracker Pro-Team 175. Mercury 60
  #5
Old June 18th, 2008, 10:25 PM
Really if the starter is in go shape so it turns the engine over well and if you have good voltage at the white switch box terminal while cranking the engine all thats left is getting the fuel to the engine, In some cases the choke plates don't seat well and also a lean mixture will make them hard to start. If you prime the carbs with a squirt can it fires right up I would look for a donor engine with a primer system and convert to it.
  #6
Old June 18th, 2008, 10:51 PM
It does seem to crank slower than my inline 4 80hp, but not sure how slow. Will check that when I get a tach.
Saw a picture of a primer system where the choke plates were removed and the solenoid rerouted to actually lets fuel into the front of the carbs through little copper tubes.
So if I found a newer model carbs (80s or so) with the enrichment circuit, that would work with my existing setup?
__________________
1972 Macgregor 25'
  #7
Old June 19th, 2008, 09:15 AM
You would use your carbs all you need is the fitting that screws into the top cab, primer assm and the plumbing. Think you will have to build the mount for the primer as the new engines the crankcase is tapped.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
74 1150 trim gregtobin Mercury & Mariner Outboards 1 July 10th, 2007 03:51 PM
74 1150 merc? digger6106 Mercury & Mariner Outboards 3 August 10th, 2006 11:42 PM
Reed Cages OBJ Johnson & Evinrude Outboards 3 December 15th, 2005 09:15 AM
reed cages and yamabond isnms Mercury & Mariner Outboards 1 November 17th, 2005 10:56 AM
Merc 1150 reed valve location AEROCOOK Mercury & Mariner Outboards 17 November 9th, 2005 10:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
