  #1
Old June 18th, 2008, 01:29 AM
Dakota4x4 Dakota4x4 is offline
Default Hard to start 2007 25 hp yamaha after sitting 2 weeks
Hi everyone i have a 2007 25 hp yamaha outboard that is realy hard to start after sitting a couple weeks..If it only sits a week it starts right up but after 2 weeks i can prime the ball and choke the liveing sh_t out of it and it wont fire unless i squirt a little fuel into the carbs or plug holes first ?Any help would be appreciated..Also one of those little black low speed idle mixture knobs is broke off on the botton carb does this matter as it idles real nice foe at least a half hour befour it starts to foul..Thanks a bunch from Dakota4x4Ps the ball on the hose gets good and hard so i dont think its the tank or hose ?
  #2
Old June 18th, 2008, 02:20 AM
scottcmb scottcmb is offline
Send a message via MSN to scottcmb
Default Re: Hard to start 2007 25 hp yamaha after sitting 2 weeks
Check your fuel lines from tank to motor,clean the fuel filter, check diaphrams in the fuel pump, good cleaning and thorough inspection of the carbs, replace your broken mixture screw, re-syncronize the carby's and tune the mixture screws, compression test,new plugs etc etc......in other words a FULL service
  #3
Old June 18th, 2008, 11:05 AM
Thanks scottcmb for the info,this motor is like new only used a few months last year so carbs shouldnt need rebuilding yet ? I have cheaked the hose and ball,the fuel filter was clean as a whistle and the motor was winterized by the dealer..Its going back to the dealer as i still have till sept 1st 2008 dealer extended warranty on it..Hopefully they will fix the broken mixture screw as its a pre set one with only minute adjustment on it anyways. so idle mixture must be preset at factory as you can only adjust the idle mixture screws about a 1/16th of a turn?Put new plugs in when i bought it as well so i guess only thing left is the fuel pump diafram or maybe something in the choke ? thanks again from Dakota4x4
  #4
Old June 18th, 2008, 07:58 PM
what im curious about is HOW did the mixture screw get broken in the first place??......and another little tip.....a new or near new motor is only as good and clean as the fuel that goes into it!!!.......in other words the motor can only be as clean and water free as what is in your fuel tank and the quality of the fuel.......has your fuel been sitting around in the tank since the last time you used it before you "Winterised" the motor???........are you using E-10??
You say that you got your dealer to winterise the motor......did you ask, or did he state what the procedure is to de-winterise the motor for re-use?
im just stating and asking all this stuff in the hope it might jog your memory on something that might have been easily overlooked.......are the choke butterflies closing when you operate it??(linkage accidently dissconnected)
is it a warranty job??(unlikely but possible)
hope this helps
  #5
Old June 19th, 2008, 02:52 AM
Hi Scottcmb and thanks for staying in touch..The mixture screw is a pre set from factory with the largest part inside of the carb..The piece on top of carb is a very small diameter brass about half the thickness of a pensil lead with a plastic knob on it to fine tune the adjustment about a 32nd either way..I pushed on it when the motor was on lake in boat running to see if i could get her to idle slower without stalling and it broke off and i didnt put much pressure on it..Had the boat out today and slammed the walleys and she trolled slower than my 9.9 for about 30 minutes befour i needed to open her up to clean the plugs.The only thing i havent looked at yet is the choke butterflys to see if they are closeing all the way..The motor goes in monday to be cheaked under warranty..Oh the guy at yamaha dealer said to use premium fuel from shell as it dont have any alcohol in it ..Thanks again..
  #6
Old June 19th, 2008, 06:43 AM
rodbolt rodbolt is offline
to start with your diddling with the wrong screw for idle speed.
idle speed is set after the linkage and the air/fuel screws are set and the idle speed is set at what the manufactuer says, if the trolling speed is now to fast, tow a sea anchor.
biggest cause of carb rebuild is simply lack of use.
find a real dealer,please, do everyone a favor.
read your owners manual about fuel reccomendations.
you will most likly have to chose between Yamaha's words in the manual or the dealerships reccomendation.
trust me the manual is way more correct on fuel type. almost all modern 2 and 4 stroke yamahas are designed for regular unleaded and power will decrease if higher octane fuels are used.
your describing a choke shutter that fails to close completly, if the is a non oil injected motor run a 50/1 fuel mix. thats one of the few areas me and yamaha dissagree in writing but my services reps all agree with me.
and those plastic knobs are EPA mandated fuel mixture limiter screws.
breakage isnt a warrenty item.
a model number may help as we have no clue WHICH 25 HP motor we are disscusing.
  #7
Old June 19th, 2008, 12:51 PM
Thumbs up Re: Hard to start 2007 25 hp yamaha after sitting 2 weeks
Hi Rodbolt and thanks for your reply and info..Noi dont mean the idle screw i meant the fuel jet which has the epa fuel limiter black nob on top is what i broke off on bottom carb lol? Yes it says in manual to use regular unleaded octone 87 and thats what i use but the dealer says to use premium ?The mixture is 100-1 its a non fuel injected motor i used 70-1 on my old 1988 20 hp yamaha outboard for the longest time with great success so i mix the new one at 80-1 but only use yamaha 2 stroke oil in it with the anty sticking and anti scuffing additives in it.Trolls nice and doesnt defogg the mosquitos lol or my lungs ?The model # is 25MSH serial# is 1016859 2007 yamaha 25 hp short shaft rope start..Rodbolt i will look up on google about the EPA mixture screws to see what they are exactly for and will just leave them alone till a few years down the raod when i take the carbs off to rebuild from whare and tear.wont try to screw the limiter mixtuer jet out as i have no idea whare its to be set again there is enough to grab it with a needle nose pliers though.Thanks a bunch for all your help ..Dakota4x4
  #8
Old June 19th, 2008, 02:03 PM
matt2002's Avatar
matt2002 matt2002 is offline
Go by what the manual says , not the dealer , in regards to fuel octane.After all , he is in the business of selling new motors.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 yamaha excel idles rough on 1st start after sitting overnight with motor tilted wwb1969 Yamaha & Suzuki Outboards 2 May 27th, 2008 12:56 PM
2007 90 TLR hard to start Case Biezenbos Yamaha & Suzuki Outboards 22 January 28th, 2008 09:01 PM
hard start for '81 25 HP Johnson katz Johnson & Evinrude Outboards 5 February 8th, 2006 04:21 PM
1988 25 hp yamaha won't start, Bad gas? jamakim18 Yamaha & Suzuki Outboards 1 December 30th, 2004 02:37 PM
25 hp Mariner hard to start spekltrout2002 Mercury & Mariner Outboards 3 September 1st, 2002 03:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
